Temps d'accès à la VRAM
Problématique
- La génération du VDP,
Génération et mode écran
- Yamaha V9938 (MSX2),
| 0,W40 | T1 | 12 | 20 |
| 0,W80 | T2 | -- | 20 |
| 1 | G1 | 29 | 15 |
| 2 | G2 | 29 | 15 |
| 3 | MC | 13 | 15 |
| 4 | G3 | -- | 15 |
| 5 | G4 | -- | 15 |
| 6 | G5 | -- | 15 |
| 7 | G3 | -- | 15 |
| 8 | G7 | -- | 15 |
Activité du VDP
Accès au VDP en assembleur
Remplissage
Code les plus rapides pour remplir la VRAM d'une valeur en fonction des mode d'affichages :
| Screen 0 MSX1 | Screen 3 MSX1 | Screen 1~8 MSX2 | Screen 0 MSX2 | Screen 1~2 MSX1 |
; 12 cycles
out (0x98),a
out (0x98),a
out (0x98),a
out (0x98),a
; 13 cycles
out (0x98),a
nop
out (0x98),a
nop
out (0x98),a
nop
out (0x98),a
; 15 cycles
ld c, 0x98
out (c),a
nop
out (c),a
nop
out (c),a
nop
out (c),a
; 20 cycles
ld c, 0x98
out (c),a
nop
nop
nop
nop
nop
nop
out (c),a
nop
nop
nop
nop
nop
nop
out (c),a
nop
nop
nop
nop
nop
nop
out (c),a
; 29 cycles
ld c, 0x98
ld b, #4
loop:
out (c),a
nop
djnz loop
; 26 cycles ld b, #100 loop: out (0x98),a djnz loop
Copie
OutiToVram:
outi ; send (HL) ; HL++ ; B--
Performance
| Instruction | Cycles (T-States) | Timing I/O |
| in a,(n) | 12 | 9|3 |
| out (n),a | 12 | 9|3 |
| in a,(c) | 14 | 11|3 |
| out (c),a | 14 | 11|3 |
| outi | 18 | 15|3 |
| outd | 18 | 15|3 |
| ini | 18 | 12|6 |
| ind | 18 | 12|6 |
| otir | 23 (loop) 18 (last) |
15|8 15|3 |
| otdr | 23 (loop) 18 (last) |
15|8 15|3 |
| inir | 23 (loop) 18 (last) |
12|11 12|6 |
| indr | 23 (loop) 18 (last) |
12|11 12|6 |
