CMSXImg
Version actuelle : CMSXImg 1.9.1
Exemple
Prenons l'image suivante :
> CMSXImg -in my_image.png -out my_sprites.h -pos 0 11 -size 13 11 -num 16 1 -name myYellowCar -trans 0xE300E3 -bpc 8
Code C :
Options
Code TEXT :
Usage: CMSXimg <filename> [options]
Options:
inputFile Inuput file name. Can be 8/16/24/32 bits image
-out outFile Output file name
-format ? Output format
c C header file output
bin Raw binary data image
-gap x y Gap between blocks in pixels
2 2-bit index in 4 colors palette
msx1 Use default MSX1 palette
-compress ?
none No compression (default)
auto Determine a good compression method according to parameters
best Search for best compressor according to input parameters (smallest data)
none No dithering (default)
bayer4 Bayer ordered dispersed dot dithering (order 2 – 4x4 - dithering matrix)
bayer8 Bayer ordered dispersed dot dithering (order 3 – 8x8 - dithering matrix)
bayer16 Bayer ordered dispersed dot dithering (order 4 – 16x16 dithering matrix)
cluster6 Ordered clustered dot dithering (order 3 - 6x6 matrix)
cluster8 Ordered clustered dot dithering (order 4 - 8x8 matrix)
cluster16 Ordered clustered dot dithering (order 8 - 16x16 matrix)
dec Decimal data (c & asm)
-idx Add images index table (default: false)
-copy (file) Add copyright information from text file
If file name is empty, search for <inputFile>.txt
-head Add a header table contening input parameters (default: false)
-font x y f l Add font header (default: false)
x/y: Font width/heigt in pixels
f/l: ASCII code of the first/last character to export
Can be character (like: &) or hexadecimal value (0xFF format)
-def Add defines for each table (default: false)
-notitle Remove the ASCII-art title in top of exported text file
-help Display this help
Déscription
Fichier source
-in path\fileName
Fichier destination
-out path\fileName
-format auto | c | asm | bin
Détermine le format d'export.
-name tableName
Découpage des sprites
-pos x y
-size x y
-num x y
Nombre de blocks à extraire.
-skip
Couleurs
-trans color
-bpc 1 | 4 | 8
-pal msx1 | custom
-palcount n
Compression
Crop
| Nom | Taille max | Entête | Remarque |
| Crop16 | 16x16 px | 2 bytes : [minX:4|maxX:4] [minY:4|maxY:4] | |
| Crop32 | 32x32 px | 2 bytes : [minX:3|maxX:5] [minY:3|maxY:5] | La valeur minimum de X et Y n'étant codé que sur 3-bits (valeurs 0 à 7), la zone transparente "taillé" ne peut excéder cette taille même s'il n'y a pas de pixel non-transparent au delà |
CropLine
| Nom | Taille max | Entête sprite | Entête ligne | Remarque |
| CropLine16 | 16x16 px | 1 byte : [minY:4|maxY:4] | 1 byte : [minX:4|maxX:4] | |
| CropLine32 | 32x32 px | 1 byte : [minY:3|maxY:5] | 1 byte : [minX:3|maxX:5] | La valeur minimum de X et Y n'étant codé que sur 3-bits (valeurs 0 à 7), la zone transparente "taillé" ne peut excéder cette taille même s'il n'y a pas de pixel non-transparent au delà |
| CropLine256 | 256x256 px | 2 bytes : [minY] [maxY] | 2 bytes : [minX] [maxX] |
RLE
| Nom | Longueur max | Encodage |
| RLE4 | 16 | 1 byte : [length:4|color:4] |
| RLE8 | 256 | 2 bytes : [length] [color] |
RLE0
Auto
Le programme essaye de sélectionner un mode de compression standard en fonction des paramètres d'entrée (en fonction de la taille des sprites et de mode couleur 1/4/8-bits).
Best
Le programme génère les données dans tous les modes de compression possibles, puis sélectionne le meilleur (celui qui génère les données les plus petites).
