CMSXImg
Version actuelle : MSXImage 1.6.3
Exemple
Prenons l'image suivante :
![](/upload/cars.jpg)
Code C :
Options
Code TEXT :
Usage: MSXImage [options] Options: -in fileName Inuput file name. Can be 8/16/24/32 bits image Supported format: BMP, JPEG, PCX, PNG, TGA, PSD, GIF, etc. -out fileName Output file name -format ? Output format auto Auto-detected using output file extension (default) c C header file output asm Assembler header file output bin Raw binary data image -name name Name of the table to generate -data ? Text format for numbers dec Decimal data (c & asm) hexa Default hexadecimal data (depend on langage; default) hexa0x Hexadecimal data (0xFF; c & asm) hexaH Hexadecimal data (0FFh; asm only) hexa$ Hexadecimal data ($FF; asm only) hexa# Hexadecimal data (#FF; asm only) bin Binary data (11001100b; asm only) -pos x y Start position in the input image -size x y Width/height of a block to export (if 0, use image size) -num x y Number of block to export (columns/rows number) -skip Skip empty sprites (default: false) -trans color Transparency color (in RGB 24 bits format : 0xFFFFFF) -bpc ? Number of bits per color for the output image (support 1, 4 and 8-bits) 1 1-bit black & white (0: tranparency or black, 1: other colors) 4 4-bits index in 16 colors palette 8 8 bits RGB 256 colors (format: [G:3|R:3|B2]; default) -pal Palette to use for 16 colors mode msx1 Use default MSX1 palette custom Generate a custom palette and add it to the output file -palcount n Number of color in the custom palette to create (default: 15) -dither ? Dithering method (for 1-bit color only) none No dithering (default) floyd Floyd & Steinberg error diffusion algorithm bayer4 Bayer ordered dispersed dot dithering(order 2 – 4x4 - dithering matrix) bayer8 Bayer ordered dispersed dot dithering(order 3 – 8x8 - dithering matrix) bayer16 Bayer ordered dispersed dot dithering(order 4 – 16x16 dithering matrix) cluster6 Ordered clustered dot dithering(order 3 - 6x6 matrix) cluster8 Ordered clustered dot dithering(order 4 - 8x8 matrix) cluster16 Ordered clustered dot dithering(order 8 - 16x16 matrix) -compress ? none No compression (default) crop16 Crop image to non transparent area (4-bits, max size 16x16) cropline16 Crop image to non transparent area (4-bits per line, max size 16x16) crop32 Crop image to non transparent area (5-bits, max size 32x32) cropline32 Crop image to non transparent area (5-bits per line, max size 32x32) crop256 Crop image to non transparent area (8-bits, max size 256x256) cropline256 Crop image to non transparent area (8-bits per line, max size 256x256) rle0 Run-length encoding of transparent blocs (7-bits for block length) rle4 Run-length encoding for all colors (4-bits for block length) rle8 Run-length encoding for all colors (8-bits for block length) -help Display this help
Déscription
Fichier source
-in path\fileName
Fichier destination
-out path\fileName
-format auto | c | asm | bin
Détermine le format d'export.
-name tableName
Découpage des sprites
-pos x y
-size x y
-num x y
Nombre de blocks à extraire.
-skip
Couleurs
-trans color
-bpc 1 | 4 | 8
-pal msx1 | custom
-palcount n
Compression
Crop
Nom | Taille max | Entête | Remarque |
Crop16 | 16x16 px | 2 bytes : [minX:4|maxX:4] [minY:4|maxY:4] | |
Crop32 | 32x32 px | 2 bytes : [minX:3|maxX:5] [minY:3|maxY:5] | La valeur minimum de X et Y n'étant codé que sur 3-bits (valeurs 0 à 7), la zone transparente "taillé" ne peut excéder cette taille même s'il n'y a pas de pixel non-transparent au delà |
Crop256 | 256x256 px | 4 bytes : [minX] [maxX] [minY] [maxY] |
![](/upload/sprite_crop16.jpg)
CropLine
Nom | Taille max | Entête sprite | Entête ligne | Remarque |
CropLine16 | 16x16 px | 1 byte : [minY:4|maxY:4] | 1 byte : [minX:4|maxX:4] | |
CropLine32 | 32x32 px | 1 byte : [minY:3|maxY:5] | 1 byte : [minX:3|maxX:5] | La valeur minimum de X et Y n'étant codé que sur 3-bits (valeurs 0 à 7), la zone transparente "taillé" ne peut excéder cette taille même s'il n'y a pas de pixel non-transparent au delà |
CropLine256 | 256x256 px | 2 bytes : [minY] [maxY] | 2 bytes : [minX] [maxX] |
![](/upload/sprite_cropline16.jpg)
RLE
Nom | Longueur max | Encodage |
RLE4 | 16 | 1 byte : [length:4|color:4] |
RLE8 | 256 | 2 bytes : [length] [color] |
![](/upload/sprite_rle4.jpg)
![](/upload/sprite_rle8.jpg)
RLE0
![](/upload/sprite_rle0.jpg)
