PRINT WIP
WIP
PRINT TAB
PRINT USING
PRINT#
PRINT USING "!"
PRINT USING "\ \"
PRINT USING "& &"
PRINT USING "#"
PRINT USING "."
PRINT USING ","
PRINT USING "+"
PRINT TAB
PRINT USING
PRINT#
| Exemple en msx-basic |
| Résultat |
Remarques:
| Résultat |
| Résultat |
PRINT USING "!"
| Résultat |
PRINT USING "\ \"
| Exemple |
| Résultat |
PRINT USING "& &"
| Exemple |
| Résultat |
PRINT USING et les nombres
PRINT USING "#"
| Résultat |
PRINT USING "."
| Résultat |
PRINT USING ","
| Résultat |
PRINT USING "+"
| Résultat |
